    HORN BUTTON removal
    SDEconoTruck
    SDEconoTruck
    Number of posts : 310
    HORN BUTTON removal Empty HORN BUTTON removal
    Post by SDEconoTruck Sun Jun 13, 2010 11:12 pm
    It should be easy, done it many times with my Falcons. Push down, twist left (CCW) and the
    horn button is in your hands...
    HORN BUTTON removal Imgp7230
    My Horn Button is spinning.
    I push down, twist, and with a lot of resistance, I can spin the Horn Button a full rotation!!! Shocked
    Horn still works fine, button is still on tight, nothing weird- I just can't get it off... Evil or Very Mad
    If anyone has a picture of the backside of the Horn Button, so I can see what is spinning free, maybe
    I can come up with a good solution (other than destroying the Horn Button in the process of removal.)
    If anyone has any ideas on how to solve this, please suggest- no hurry though, it's not like I have a
    leaking undersea oil well on my hands... Suspect
    Thanks in advance,
    George
    Number of posts : 2067
    HORN BUTTON removal Empty Re: HORN BUTTON removal
    Post by sasktrini Mon Jun 14, 2010 12:08 am
    metal must be spinning around the plastic assembly inside... that is how you remove the horn. Maybe make sure you have a firm squeeze on the perimeter of the buttonin an attempt to hold the horn mechanism past the locking tabs?
    Hope that helps. (in lieu of an actual horn button pic at the moment)
    Number of posts : 2198
    Post by EconoUSAparts Mon Jun 14, 2010 9:10 am
    Maybe it doesnt have the spring under it or a weak or different spring. Without a good spring it wont pop off. Try pulling up on it occasionally after pressing down and turning. You may get lucky if the slots are aligned right.
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Mon Jun 14, 2010 11:44 pm
    Hi Sasktrini,
    Yes it seems that way, the Metal Button can be spun with a fit
    of brute force. Kinda surprised I'm not breaking the plastic
    fingers.
    Hi EconoUSAparts,
    Seems to be spring-loaded, the horn works, and the button returns
    to position with no sticking. I tried pulling up, even squeezing the metal,
    then pushing down again and turning- no luck yet.
    So I am thinking the Horn Button backside is similar to the Falcons of
    the same period? (3 plastic prongs spaced pretty evenly apart, that
    engage into the potmetal steering wheel hub.) Oh and the slots in
    the hub are narrow for almost a quarter turn, then they get wider
    for clearance of the prongs???
    I gave up after getting up a pretty good sweat, then I was leaning
    against the bed, and an earthquake hit...
    ...I took it as a sign and stopped.
    But I plan to continue! A pic of the button's backside might help me
    come up with some kind of scheme to get the button removed.
    George
    Number of posts : 466
    Post by Sy Hollinshead Tue Jun 15, 2010 9:13 am
    Just went over to the garage and took a couple of piccies for you.... Mine has a horn ring on it, so it might be slightly different, but it used to have a normal horn button on it, so i know the wheel part is the same....
    HORN BUTTON removal CIMG1405
    HORN BUTTON removal CIMG1404
    The mechansim is all metal, and requires a slight anti clockwise turn to disengage.... Not sure which bit might be broken on yours...
    Regards
    Sy
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Tue Jun 15, 2010 9:39 am
    Thank You Sy!!!
    That totally helps! Much different than the Falcons to which
    I am accustomed. Trying to figure out what might be spinning
    free on my set-up...
    ...I can turn my horn button a full revolution with a lot of effort.
    (Whilst pushing down, or not)
    George
    Post by Sy Hollinshead Tue Jun 15, 2010 1:51 pm
    Yeah, i'm not sure what is going on with yours. The 3 screws you can see on the back of the horn ring are actually fixing the metal plate to the horn button. These must still be intact on yours, as the horn would come apart without them. I wonder if the receiver plate is spinning round. I'm not sure what holds it in place, although there are 3 dots that could be spot welds or rivets or something on it. Maybe these have come loose.
    Post by EconoUSAparts Tue Jun 15, 2010 4:47 pm
    If the horn works,the plate cant be spinning even if the welds are broke. The black plastic horn spring insulator(shown in the steering wheel picture) goes thru it preventing it from spinning.
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Wed Jun 16, 2010 12:07 am
    Got the Horn Button off.
    Having those pics helped me focus my efforts a little better. Basically
    I gripped the Horn Button real good, then bounced down and twisted
    at the same time, HARD, trying to shock it into motion. Each time the Button
    returned to original position.
    Then after about 2 dozen tries, the Button stayed down Cool
    Moreso on one side, so I knew the other two prong positions because
    of it, and focused there, keeping pressed down whilst turning...
    HORN BUTTON removal Imgp7231
    kept at it and finally...
    HORN BUTTON removal Imgp7232
    removed the proper way (without damage.)
    HORN BUTTON removal Imgp7238
    Thanks to you guys I kept on it, and was able to figure out what happened:
    HORN BUTTON removal Imgp7234
    As mentioned, the black plastic liner inside the Stainless Horn Button was
    slipping within the Stainless. I can see that the plastic was distorted a
    bit and/or the Stainless was pulled back from the plastic, thereby losing
    grip...
    HORN BUTTON removal Imgp7235
    ...further evidence that this is the slippage point, is the mismatch between
    marks on the plastic and stainless. I think the arrow on the black plastic
    is supposed to line up with the detent in the Stainless:
    HORN BUTTON removal Imgp7236
    HORN BUTTON removal Imgp7237
    See how far the marks have clocked away from one-another, (Screw driver tip is
    pointing to the detent in the Stainless.)
    I'm figuring the marks need to line up so the "Econoline" script reads horizontally
    when the steering wheel is driven straight ahead.
    With the Button off, I can reposition my steering wheel (which was why I wanted the
    Horn Button off, and maybe try and fix the flaws in the wheel. (another thread?))
    Also have to find a fix for the Horn Button, maybe re-crimp
    the edges of the stainless onto the black plastic (?)
    I will need to fix the Button because I will want to remove the Horn Button
    in the future (I might swap the column out for an automatic version I've
    got...)
    George
    Post by sasktrini Wed Jun 16, 2010 7:42 am
    Wow, I got one right on the first guess! Laughing
    Glad it worked.
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Wed Jun 16, 2010 7:58 pm
    Sasktrini,
    That was a guess? I took it as solid fact and ran with it... Laughing ha ha ha.
    Now I got to come up with a repair. You guys familar with Gorilla Glue?
    Maybe something expandable like that would create enough interference/hold?
    G
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Wed Jun 16, 2010 11:10 pm
    So, there I was this evening, sitting in my Econoline, in the garage making
    motor noises when this fell into my lap:
    HORN BUTTON removal Imgp7241
    It is 1/3 of the center of the Steering Wheel. Surprised at how much it
    weighed...
    HORN BUTTON removal Imgp7242
    "Hayyy, is it supposssed to do thaaat???"
    Looks like I might do a thread on how to restore a steering wheel...
    George
    Post by sasktrini Thu Jun 17, 2010 10:47 am
    Wow! Listen, there is an excellent blog. the author passed away a couple months ago, but his last entry was a steering wheel restoration.
    Ron Blachut's 1965 Ford Econoline Pickup Restoration
    SDEconoTruck
    SDEconoTruck
    Post by SDEconoTruck Mon Jun 21, 2010 11:21 pm
    Hey Corey,
    I looked at that Blog way before I even got my own 'conoline.
    That is sad news that he passed away, it looked like he got
    all the body painted... ...that's terrible news.
    George
      Current date/time is Thu Apr 18, 2024 11:05 pm
