Hi Guys,
I've been searching around and found little information on how the Belly Pans are configured.
The Manual unfortunately does not give any leads either, so I thought I would tap into the V-V's
braintrust...
(overall view, leading edge is along the ground, size is about 3 feet square)
(pan has a slope to it, and sidewalls. Front is at the left in photo)
(an important hunk of metal, supposed to force air into the engine/doghouse for cooling.)
I found the most info looking at Belly Pans on e-bay. Turns out there are two types
with the one above for earlier Econo's (mine's a '61.) I found that the later ones, which
look more rounded in contours, had side duct pieces to go with the main pan.
What I am seeking is information about this earlier pan- Does it have other pieces
like the later 3-piece Belly Pans?
Thanks in advance,
George
braintrust...
Thanks in advance,
George
Last edited by SDEconoTruck on Sun Jun 06, 2010 7:55 pm; edited 1 time in total (Reason for editing : better photo added)
