Between The Seats 'G'
Topics | Replies | Author | Views | Last Posts | ||
External Coil Test? | 8 | Scott | 1494 | Sun Nov 28, 2010 5:11 am by Scott | ||
low disc brake pedal, two possible items | 4 | m1dadio | 868 | Tue Nov 23, 2010 5:53 pm by donivan65 | ||
Low disc brake pedal experiment | 0 | m1dadio | 1620 | Mon Nov 01, 2010 9:07 pm by m1dadio | ||
Drip rail Moulding CLIPS | 12 | Roman | 1491 | Thu Oct 21, 2010 3:25 pm by Roman | ||
Tie Rod End | 8 | Guest | 990 | Thu Sep 30, 2010 7:46 pm by Guest | ||
#rg. Gen- parts used on 2nd gen=?? | 3 | Twinpilot001 | 705 | Tue Sep 28, 2010 6:15 pm by Twinpilot001 | ||
gasket for the sending unit | 3 | pan58head | 740 | Sun Sep 19, 2010 10:10 pm by pan58head | ||
Fuel filter in carb | 3 | sparky | 926 | Sun Sep 19, 2010 6:09 pm by Twinpilot001 | ||
Pulling V8 motor 1, 2 | 30 | veefre | 3935 | Sun Sep 19, 2010 6:04 pm by Twinpilot001 | ||
speedo pointer replacement | 2 | pan58head | 744 | Wed Sep 15, 2010 11:02 pm by pan58head | ||
gasket for the sending unit | 0 | pan58head | 495 | Wed Sep 15, 2010 8:40 am by pan58head | ||
Radiator Fix? | 17 | Scott | 1848 | Fri Sep 10, 2010 4:05 pm by donivan65 | ||
2nd gen to first gen eng. and tranny swap, (installing a 250 and auto from a 68 into a 66) | 5 | sparky | 739 | Sat Sep 04, 2010 3:15 am by sparky | ||
axel c clip removal | 2 | BILLS66 | 604 | Sun Aug 29, 2010 4:28 pm by BILLS66 | ||
L6 charging system problems.... | 7 | Guest | 2256 | Tue Aug 17, 2010 8:42 am by Guest | ||
V8 lower radiator hose........................ | 0 | mo_1040 | 552 | Mon Aug 02, 2010 7:37 pm by mo_1040 | ||
Gearing question? | 4 | DanTheVanMan | 771 | Tue Jul 27, 2010 3:08 pm by Digz | ||
Do Back up light replacements for 1st gens exist? | 5 | Guest | 786 | Tue Jul 27, 2010 12:35 pm by RodStRace | ||
Van runs OK! | 12 | m1dadio | 905 | Thu Jul 22, 2010 9:24 pm by sasktrini | ||
Fire Starter or Needed? Which Alternator do I use, and how many AMPS? | 4 | Scott | 1138 | Tue Jul 20, 2010 6:49 pm by 61econoline | ||
2nd gen seats into a 1st gen Q's | 2 | m1dadio | 733 | Sun Jul 18, 2010 1:43 am by kookykrispy | ||
What Carb is it? | 24 | Scott | 1964 | Fri Jul 16, 2010 11:53 pm by veefre | ||
3rd gen power stering in V8 adapt to 250 straight 6? | 7 | Guest | 1306 | Thu Jul 15, 2010 5:56 pm by panelmanrd | ||
GM Rebuilt Rochester One Barrel Carburetor (In Old Box) | 0 | Scott | 1393 | Fri Jul 02, 2010 12:41 pm by Scott | ||
200-4R Transmission >> What Else? << | 2 | Scott | 796 | Sun Jun 27, 2010 3:27 pm by Scott | ||
cutting the dash for a deck | 10 | Guest | 990 | Mon Jun 21, 2010 1:07 pm by richie61 | ||
I need your help...carburetor issue | 2 | Boogie Van | 733 | Thu Jun 17, 2010 11:07 pm by Boogie Van | ||
PCV Question V8 | 10 | Digz | 766 | Wed Jun 16, 2010 9:59 pm by Nightmoves | ||
Anyone know a great mechanic in Northern California? | 5 | redsockss | 657 | Sun Jun 13, 2010 6:27 pm by redsockss | ||
Coil Questions | 18 | Scott | 1523 | Tue Jun 08, 2010 11:46 pm by Guest | ||
Windshield washer pump? | 4 | Matt Hagan | 622 | Sat Jun 05, 2010 9:38 pm by Matt Hagan | ||
something strange | 4 | Guest | 715 | Fri Jun 04, 2010 1:20 pm by RodStRace | ||
spark plug wires? | 1 | wbulick76 | 880 | Fri May 21, 2010 12:18 pm by donivan65 | ||
dyno van cam | 3 | m1dadio | 1092 | Thu May 20, 2010 7:52 am by ChevyVanMan1 | ||
Removing an I6 oil pan???? | 3 | wideload | 700 | Sun May 16, 2010 5:46 pm by wideload | ||
Hinge Grommets | 2 | donivan65 | 1062 | Sun May 16, 2010 2:24 am by sparky | ||
Monojet Help | 6 | Guest | 788 | Fri May 14, 2010 6:21 pm by donivan65 | ||
Ritchies 66 GMC 1, 2, 3 | 63 | donivan65 | 5034 | Tue May 04, 2010 8:12 pm by donivan65 | ||
64 Chevy Ignition Switch Wiring ? | 5 | 63chevyvan? | 2157 | Sat May 01, 2010 12:21 am by 63chevyvan? | ||
Trouble on I-99 Seattle 1, 2 | 48 | Guest | 4213 | Fri Apr 16, 2010 8:54 pm by Guest | ||
2nd gen steering wheel fit 1st gen? | 1 | Guest | 808 | Wed Apr 14, 2010 10:43 pm by richie61 | ||
wiring help 1, 2 | 28 | wacko | 2026 | Fri Apr 09, 2010 10:03 am by donivan65 | ||
who know about knock sensors?? | 8 | m1dadio | 905 | Wed Mar 24, 2010 8:12 am by RodStRace | ||
Spray Adhesive for stock headliner? | 5 | wacko | 1278 | Mon Mar 22, 2010 7:17 pm by wacko | ||
smoke out of breather cap on I6 | 13 | Guest | 1440 | Thu Mar 11, 2010 2:01 pm by Guest | ||
Early fuel injection conversion? 1, 2 | 41 | veefre | 3644 | Tue Mar 09, 2010 10:57 am by donivan65 | ||
How to remove the fron Chevy Bowtie | 1 | Guest | 1279 | Wed Mar 03, 2010 7:54 pm by G-Man | ||
bought a 292, now planning the swap into my 1st gen chevy. | 1 | kookykrispy | 930 | Tue Mar 02, 2010 8:26 pm by wideload | ||
Heater Core | 2 | Guest | 1088 | Sun Feb 28, 2010 6:53 pm by Guest | ||
Fuel Gauge Pegged 1, 2 | 27 | veefre | 2923 | Mon Feb 22, 2010 10:52 am by kiwimopar |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
