Between The Seats 'A'
Topics | Replies | Author | Views | Last Posts | ||
Balancer question | 9 | Stoopid john | 990 | Sun Jul 17, 2011 12:15 pm by donivan65 | ||
Carter 2bbl flooding ? | 16 | vanitarium | 5345 | Sat Jul 16, 2011 5:30 pm by slowflapper | ||
a little more done................................ | 7 | wylee | 812 | Tue Jul 12, 2011 1:00 am by Mr. John | ||
Diagnosis Help (hard to idle) | 14 | slowflapper | 964 | Mon Jul 11, 2011 9:37 am by slowflapper | ||
Leaf Shackles | 6 | white-lightning | 927 | Mon Jul 04, 2011 7:51 pm by Digz | ||
Alternator Output / Overcharging? | 4 | slowflapper | 834 | Mon Jul 04, 2011 11:40 am by slowflapper | ||
Tuning using a vacuum gauge + O/T | 7 | itruns | 1989 | Wed Jun 29, 2011 4:53 am by Twinpilot001 | ||
opinions on pertronix dist modules? 1, 2 | 28 | Guest | 3810 | Tue Jun 28, 2011 3:27 pm by mrfoochie | ||
Starter question | 8 | Stoopid john | 796 | Sun Jun 26, 2011 5:18 pm by Guest | ||
Bumpers and options | 1 | Kip Page | 1140 | Mon Jun 20, 2011 7:08 am by slowflapper | ||
Air Cleaner fitment | 6 | white-lightning | 969 | Fri Jun 17, 2011 7:57 am by white-lightning | ||
67 A108 shifter | 12 | Guest | 1180 | Mon Jun 06, 2011 10:42 pm by Guest | ||
clutch assm parts? | 3 | oo3 | 751 | Sat May 28, 2011 5:10 pm by oo3 | ||
'65 A100 Brake Light Switch | 5 | slowflapper | 3646 | Tue May 24, 2011 4:34 pm by 67a 100 pickup | ||
Dog dish for my steel wheels | 2 | Kip Page | 1246 | Sun May 22, 2011 4:04 pm by Kip Page | ||
Rear Axle / Leaf Spring Wedge / Pinion Angle? 1, 2 | 28 | slowflapper | 7753 | Tue May 03, 2011 11:08 am by kiwimopar | ||
mount this......... | 5 | wylee | 1137 | Sun Apr 03, 2011 11:19 am by Henrik | ||
hood prop rod | 9 | panelmanrd | 1259 | Fri Mar 18, 2011 10:22 am by panelmanrd | ||
Total meltdown | 13 | Guest | 1110 | Wed Mar 16, 2011 6:08 am by Guest | ||
'65 DS Tail Light Removal | 6 | white-lightning | 848 | Sun Mar 13, 2011 8:24 pm by white-lightning | ||
Well, it beat me. | 4 | slowflapper | 935 | Thu Mar 03, 2011 1:03 pm by Twinpilot001 | ||
Am i missing a nut? | 4 | peter73 | 766 | Mon Feb 28, 2011 10:25 pm by donivan65 | ||
69 a100 using both solid state and mechanical regulators. ? ? | 8 | Guest | 1173 | Sun Feb 27, 2011 6:57 am by 67a 100 pickup | ||
Door hinge sealing? | 5 | white-lightning | 1006 | Sun Feb 27, 2011 5:34 am by 67a 100 pickup | ||
v8 compression | 11 | benwah | 866 | Wed Feb 23, 2011 7:47 pm by Digz | ||
here is the tranny bushing i used.. | 0 | dix | 729 | Fri Feb 18, 2011 12:24 pm by dix | ||
back from the car wash..... | 4 | wylee | 843 | Fri Feb 18, 2011 12:15 pm by dix | ||
A100 headers ? | 12 | Guest | 4532 | Mon Feb 14, 2011 2:16 pm by Guest | ||
wheel cylinder | 1 | Harley69A108 | 785 | Fri Feb 04, 2011 1:18 pm by slowflapper | ||
wheel cylinder | 0 | Harley69A108 | 572 | Thu Feb 03, 2011 2:13 pm by Harley69A108 | ||
1968 Dodge A108 360 .40 over rebuild | 3 | MASouders | 2918 | Thu Jan 27, 2011 5:53 pm by MASouders | ||
1968 Dodge A108 | 0 | MASouders | 1856 | Mon Jan 24, 2011 6:28 pm by MASouders | ||
1968 Dodge A108 | 0 | MASouders | 1058 | Sun Jan 23, 2011 2:24 pm by MASouders | ||
'65 A100 / A745 3-Speed / Clutch Kit? | 5 | slowflapper | 2008 | Wed Jan 19, 2011 4:33 pm by dix | ||
Getting There. | 3 | bigblock666 | 733 | Sun Jan 16, 2011 8:16 am by kltcustoms | ||
looking for info and ideas for a NON-mopar engine swap... | 14 | Guest | 1275 | Wed Jan 05, 2011 9:02 pm by Guest | ||
brake power booster | 6 | Henrik | 1186 | Sun Dec 12, 2010 9:47 am by Twinpilot001 | ||
v8 install parts? | 6 | cochise1304 | 867 | Mon Nov 29, 2010 1:22 pm by 67a 100 pickup | ||
Halp :) Distributor is Broken | 5 | slowflapper | 754 | Mon Oct 04, 2010 6:41 am by slowflapper | ||
'65 Carb Trouble | 10 | slowflapper | 932 | Tue Sep 28, 2010 6:41 am by RodStRace | ||
body issue | 5 | plumcrazy704406 | 1300 | Tue Aug 10, 2010 5:04 pm by plumcrazy704406 | ||
Lap seat belts | 12 | 67a 100 pickup | 1680 | Mon Aug 02, 2010 8:26 am by slowflapper | ||
A745 Transmission Fluid Change | 1 | Guest | 2078 | Sat Jun 26, 2010 6:19 pm by 67a 100 pickup | ||
BBD Carb mixture screw adjustments | 3 | 67a 100 pickup | 1598 | Fri Jun 04, 2010 7:07 pm by RodStRace | ||
A100 power steering problem | 9 | Guest | 1401 | Mon May 17, 2010 3:50 am by BajaCharlie | ||
HELP WITH POWER STEERING ON A108 | 4 | BajaCharlie | 832 | Sun May 02, 2010 4:07 pm by 67a 100 pickup | ||
Heater air intake box | 15 | 67a 100 pickup | 1518 | Wed Apr 28, 2010 5:02 pm by 67a 100 pickup | ||
crash sheets | 0 | 67a 100 pickup | 950 | Sun Apr 25, 2010 3:49 pm by 67a 100 pickup | ||
Bad Bog at WOT 1, 2 | 28 | Toast | 2480 | Tue Apr 20, 2010 10:01 pm by Guest | ||
Lubricating distributer | 15 | 67a 100 pickup | 1169 | Tue Apr 20, 2010 7:34 am by RodStRace |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
